powerplay
 - In front of a computer.
Hello all,
I am installing an Potter Releasing Panel for Water and Agent Extinguishing System in an Restaurant, which shuts down the Make-Up Air system and leaves the exhaust fans running during a fire. The place has a) 2 exhaust fans
b) 2 make-up air units
c) 1 kitchen exhaust
d) 2 HVAC units (used to be 2 addresses)
If I control the Low voltage controls, the make up air and HVAC that have Heat Exchangers may run over a minute to allow the heat exchanger to cool down automatically, but during a fire the fresh oxygen needs to stop and the exhaust continue to remove smoke and steam. An option I am considering is to intercept the fans within the units on the rooftop itself to immediately cut off the fresh air, instead of waiting for the unit to cool down to shut off in case of fire...would this cause an issue if the exchanger isn't allowed to cool down before the fresh air is stopped during extinguishing statem activation?
Thanks again ! ...Powerplay
