it does seem kinda strange to have one high phase, and one normal, but since the 3rd phase is missing that could be the low one. ( I assume 3 phase cuz of the OP's name on this thread). Is it single or 3 phase coming in????
Was your boat unplugged when you took the voltage readings? if not, unplug it, then check again. The problem could be on your vessel.
Since your in a Marina its up to them to find their problem, have them call a licensed electrician to verify if its in their system or the utility.
I'm also wanting to say to be real careful with that 140 V side. A LOT of 120 Volt electronic equipment these days will burn up internally if the voltage exceeds 135 Volts.
