vrema01
New User
- Phoenix, Arizona
- Carpenter / Woodworker
Retrofit 6 inches can with LED light/trim - 12 ft ceiling and require task lighting for kitchen.
I am researching and testing out different retrofit kits to replace the LED spot bulbs I have in a kitchen, and I am challenged with getting an equivalent output to the lights in place. I have tried HALO retrofit from HD, but it doesn't throw enough light down from 12 feet, and any other retrofit unit I have tried has the same issue. I want to replace the trim if possible, but after my research, I think retrofit with trim might not work if I can't get the light beam to travel far enough.
I am looking for advice. The client wants a 4,000K color, but I need to get the beam to travel to the floor for task lighting.
