When changing ballast in fluorescent fixtures (4 lamp instant start) without changing out the sockets (aka tombstones) should you cut the conductors from the old ballast and then splice (wire nut) the leads from the new ballast to the existing wires terminated on the sockets - or - should you remove the old wire and insert the wire from the new ballast in to the existing sockets?
Is there a authoritative source for either option.
Thank you for your input.
DGM195
DGM195
