I'm feeding a 480 volt, 3 ph, 3 wire piece of equipment from a 208 volt primary by reverse feeding a standard 480-208/120 volt dry transformer with 3 ph, 3 wire 208. The inspector wants a ground potential on the secondary side and has requested either a ground monitor or a 480 volt wye secondary transformer. Any reason why I shouldn't be able to sell him on corner tapping the 480 as we would a 480 to 240 delta/delta transformer? Appreciate the input.
