I was asked to check out a wiring problem in a recently purchased home. I was told the homeowner had just installed an internet connection by the local cable company. he plugged in a surge protector for both the electric and the internet connection. when plugging in the cable for the internet connection he blew the mother board, twice. Cable co. and local power co. checked and said all was ok at their end. the homeowner told me when buying the house, he asked for one receptacle in each room be grounded. Being a rehabbed home, it raised my suspicion of something I have seen before. Someone had installed a jumper between the neutral and ground screw so a plugin type tester would show correct wiring. Here's the thing. it also had reverse polarity. I first checked it with my plug in tester, it showed ok. shouldn't this have shown the reverse polarity on the tester? This is a very dangerous situation, and almost missed it myself, because my plug in tester showed that it was wired correctly. has anyone else run across this ?????
