electriciansnet
Hello all. I have an old client who is in the business of repairing high-end auto wheels and, although exhibiting bad planning and bad engineering, has just purchased this "oh so great" wheel polisher for tens of thousands of dollars. This equipment- originating in Germany is 60 Hz but its straight 460 at 1.5 kw nominal. The buildings service is 3 phase 240 delta (high leg present)
This is too big for a buck/boost so in order to achieve the 460/480 I need to reverse wire a step drown transformer. I have the freedom to install a 3,5 or whatever kva transformer I want at the panel but I need the secondary, which would be primary in this case to be 240 Delta. I tried hooking up an old 25 kva that was on hand with no load on it but most of the data was illegible except that the primary was multi-tap and the secondary was actually 230v. Needless to say it was a dirty, unbalanced voltage.
What is the most accessible; most used solution for this in the field? I have found a 3kva, 480v with a 240v 3 phase secondary for about a grand but I would like to know if this would provide the desired output or is there an easier "off the shelf" solution.
