klassicjam
New member
- USA
Hello. Can a neutral be used in a standard Step Down Transformer converted to a Step Up Transformer? We connected 120VAC (Hot & Neutral) to the Input Side (reversed) and wired the Output Side to the 220 Taps (2 legs) to equal 220 Volts at the Panel connections. The problem that we have is Unbalanced when you measure voltages to ground. We have 148VAC to one leg and 69VAC to the other leg measured to ground with the meter. We don't think this is correct. It seems the current would shift to the lower voltage leg if the panel is loaded. I appreciate your opinion with this connection.?
