Reversing motor rotation
humboldtian
New member
norcal
Similar questions have been asked here before but didn't address my particular problem. I have a split phase AC motor (for drill press) that I need to reverse the rotation of. The motor is constructed so that reversing rotation is easily accomplished. It even says right on the motor that to reverse rotation, switch the red and black leads. Everything easily accessible. No problem. Simple, right? Except that switching the leads does not in fact reverse the rotation. I've switched them back and forth 5 times now and it always rotates in the same direction; the wrong way. So my question is: what is causing this? And what can I do to rectify the situation?
Craftsman Split phase AC motor. 115V 60 HZ 1/3HP Model #113.12037
Thanks in advance----
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
