Revise Section 90.2(A) as follows:
joe tedesco
Revise the 2005 NEC Section:
"90.2 Scope.
(A) Covered. This Code covers the installation of electrical conductors, equipment, and raceways; signaling and communications conductors, equipment, and raceways; and optical fiber cables and raceways for the following:"
So that it will read as follows in the 2008 NEC:
"90.2 Scope.
(A) Covered. This Code covers the installation and use of electrical conductors, equipment, and raceways; signaling and communications conductors, equipment, and raceways; and optical fiber cables and raceways for the following:"
Reason:
Everything that is installed is also used by someone, and there are entire articles covering installation and use of many electrical products.
joe tedesco
Re: Revise Section 90.2(A) as follows:
Originally posted by don_resqcapt19:
Joe,
How could that be enforced?
Don
Don:
I am not sure, but it is true and the NFPA CMP 1 members should think about this issue very carefully.
I will submit this proposal to the NFPA.
don_resqcapt19
Illinois
retired electrician
Joe,
I think that any attempt to enforce a rule like that would be a serious affront to the 4th Amendment.
Don
don_resqcapt19
Illinois
retired electrician
Joe,
My point is that the?"use" part is not enforceable, even with 110.3(B). The AHJ just can't walk in and inspect how I am using the equipment. He would need "probable cause" and a search warrant. It would be almost impossible to find "probable cause". It makes no sense to me to have a rule that cannot be enforced.
Don
petersonra
Northern illinois
engineer
Such an insane rule would seem to require the end user to get a permit to plug an extra TV in.
I think such a rule would not only be unenforcable but widely laughed at. It would tend to make the code less enforcable.
plus there is absolutely no reason for it.
joe tedesco
Then what about AFCI's for AC Units 440.65, and other rules calling for specific safety items for hair dryers and other personal grooming appliances -- it is in the code! :confused:
don_resqcapt19
Illinois
retired electrician
Joe,
I don't think those rules belong in the code either. They are not within the scope of the code. Those things should be left to the product standards.
Don
joe tedesco
Don:
I agree, that's probably a better approach, as you suggest, however, that will never happen because the structure of the NEC Committee and NFPA's long standing affiliations with the major groups are set in stone.
I would like to hear what you would propose, for example, would you want to delete certain sections and articles from the code, Annex A, etc.?
don_resqcapt19
Illinois
retired electrician
Joe,
To start with, I think that the code, for the most part, should stop at the point where the equipment is connected to the building wiring system(the outlet). That would mean anything to do with plug and cord connected equipment should be removed.
I don't see a problem with the Annex, as that is informational only, not code rules.
Don
charlie
Indianapolis
Don, that is exactly why we revised 240.5. CMP-10 does not feel like in general that the Code should cover wiring that is not building wiring. This is a product standards issue. :D
rbalex
Mission Viejo, CA
Professional Electrical Engineer
Actually, I'd get rid of Annex A too. It implies motors are REQUIRED to be listed. Except for motors in hazardous locations, virtually no motors are listed. While California isn't even on the 2002 yet, the CBO for the project I'm working on attempted to use the revised Annex A to "Prove" that motors are required to be listed.
The problem with Annex A is that there are many products that are listed but are not required to be. For those jurisdictions that misread 90.7, Annex A is a killer.
roger
Fl
Thanks Bob. ;)
Roger
joe tedesco
Joe,
Don
Don: Please take a look at this information from UL and the impact the 2005 NEC has on their standards.
http://www.joetedesco.com/ul05.pdf
I will also email this link to you in case it gets deleted.
charlie
Indianapolis
Joe is trying to make the point that the CMPs will make changes to the Code that will effect the UL standards. :D
