I had about 15 years experience with AutoCAD before getting dropped into a Revit project. How "was" the learning curve? Geez, if I didn't have a sharp contact in our BIM/CAD department to run to, I couldn't count the number of additional hours I would haveNo, but a couple of questions:
Did you know CAD prior?
How was the learning curve?
Thanks
Joe
I had about 15 years experience with AutoCAD before getting dropped into a Revit project. How "was" the learning curve? Geez, if I didn't have a sharp contact in our BIM/CAD department to run to, I couldn't count the number of additional hours I would havewastedspent using Revit. What's worse is that not all our jobs are Revit, and the "selection" conventions, to mention one, are reversed between AutoCAD and Revit. It's the same freak'n company!! There may be value added for the customer using Revit, especially with multiple trades and someone (usually the architect) wrangling the base model(s), but if you're doing solo work I can't see it.
And I hate trying to pick an object in the middle of a drawing
Trying to select object was driving me insane, until I learned that you can hold the mouse near the thing you want to select and hit tab to cycle through selecting each object near your pointer. So its move mouse near thing I want to select, then hit tab a couple times until the desired object is highlighted.
