Rewire For Range Install?
91boz
New member
Hawaii
I am currently replacing a wall oven and cooktop with a slide in range. Both have there own 240v 30 amp circuit breakers and comes into a junction box under the cooktop. The new slide in requires a 40 amp circuit. Can I use the existing #10 wires if I double and tie them together? In theory this would make them equivalant to a 5 gauge. The 40 amp breaker would then have 2 #10 gauge wires connected to each terminal. The 2 -30 amp breakers would be taken out and replaced with the 40 amp. I know that the proper way is to run a new #6-50 or #8 -40 wire but the above method is easier to do.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
