RF Filters
shaw0486
baltimore
Hello,
I just got this project that has a scif room and a panelboard that is protected by the attached RF filters. Has anyone ever installed these? They are telling me that i need 4 of these (1) for each phase and (1) for the neutral. I am not seeing how this all ties together with the rf filter on the scif walls?
  • RF Filter Cut Sheet-100 amp.pdf
Your SCIF has tempest requirements which are a pain in the butt. It seems that some of the "wants" in a TEMPEST system are not NEC compliant. There have been updates clarifying how do can implement and still meet their rules (isolating the grounds being the biggest problem, but they allow grounds inside to terminate on the building shield and grounds outside to terminate on the building shield, so they aren't really isolated and by code cannot be).
I've never wired the filters, just seen them on the wall. Don't know if all phase conductors need to go into one filter, or if you can have one per phase. Would think you'd need 2 wires minimum, one in and one out. I'm thinking these are just giant chokes that go on each wire that only let 60 Hz through. If each phase is going through a separate filter, then you have to watch the ferrous wiring rules -- I think you'll need boxes and raceways to be non-ferrous if each phase is going to a separate filter box. A single filter enclosure which takes all phases and neutral would be nicer.
Watch everything electrical if you have more to do in this SCIF. Low voltage, phones, everything they want filtered and isolated from outside to inside. May even need a PVC raceway nipple between outside and inside.
The last update I saw for TEMPEST implementation was in 1995. Code has changed a bit since then, but even in 1995 I didn't know how to do what they wanted in a totally compliant manner.
I think that a one wire filter would act like a capacitor and dump the high frequency noise current to it's chassis. Then the mechanical connection of the filter chassis to the electrical system would eventually get back to ground. High frequency noise current doesn't always view the world the same way 60 Hz current does. If the filter is not near the service entrance, then dumping noise current on the EGC is not a good low noise idea.
