RF Harmonics Accompanied by Broadband Upconverted 120 Hz
Thank you to mpoulton and GoldDigger for your comments. I know this takes time and I appreciate your endeavors on my behalf.
More details:
- this IS an amateur radio installation wherein multiple transmitters are on the air at the same time
- the frequency"bands" are 3.5, 7, 14, 21, and 28 MHz
- the "band pairs" where the problem is more egregious are 3.5/7, 7/14, and 14/28 MHz
- up to 1,500 watts of RF is radiated WITH direction gain (yagi) antennas, further compounding things.
- the interference is ONLY when the yagis are pointed at the house. Moving the antennas in azimuith 45 degrees or more greatly diminishes the interference, and if rotated farther the interference is absolutely "gone"
- While transmitting with a kilowatt, a dummy load can be placed on the coax end where the receive antenna would be normally located and NO RF is practically noticed at the fundamental OR the second harmonic. In other words, the system appears "closed". All the interference is only coming in via the antennas intended for transmission/reception.
I agree that if the RF were causing zero crossings, one would have serious harmonic issues. However, any pn junction even if it remains forward biased is non linear due to the exponential characteristic of the junction itself. So this nonlinearity will be less than the "on/off" situation, but there is still a nonlinearity without any zero crossings. The signal level creating all this trouble is on the order of only a few hundred microvolts across 50 ohms, which is not much.
Yes, the field strength is quite high when the antennas are pointed in the direction of the house.
"Everything" in the house is exposed to the RF unquestionably. Except for the cable run up the side of the towers and inside the house, all cables are buried. The cables used are heliax - extremely RF "tight".
While the directivity of the yagi's allows me to ascertain that the troubling interference is coming directly from the house, the overall size of any one of these antennas, due to the low frequency, precludes relocating any antenna and doing any type of "probing". It is just physically not possible. I have transmitted around 29 MHz and looked around the house with a 146 MHz 3 element yagi in hopes of finding a "hot spot" at the 5th harmonic but this has proven to be unsuccessful. Having installed Corcom filters on a) all the garage door openers, b) upstairs and downstairs ACs, things have improved, however the problem is extremely bad on the 14/28 MHz pair. I will likely try sniffing with the 146 MHz yagi again since I have had some success after installing the Corcom filters.
I have had a friend listen to my signal(s) from a distance of 2-3 miles and he reports "extremely clean". No harmonics, no spurs, and no elevated phase noise.
As was mentioned, clearly the high power fundamental RF is impinging on something nonlinear while simultaneously connected to AC power, with the two signals mixing and developing this "hash" at the harmonics of the fundamental.
And finally, after introducing the RFI filters on all the garage door openers, that circuit breaker ceased to change the interference had ben the case before. Then the breakers for the AC units seemed to be the greatest contributor to the interference, thus the introduction of RFI filters there. Now those breakers cease to change the interference and another breaker is the major player. I will play this game a little longer, then probably have to concede defeat and at my next home, keep all the antennas far outside the near field of any antenna.
Again, thanks for your help.
