- Placerville, CA, USA
- Retired PV System Designer
There have been discussions earlier about RF interference from the driver circuitry in LED bulbs, highly variable between bulb manufacturer and model. The worst case discussed involved the light socket for an A19 bulb found in most garage door openers. The main symptom is that the remote control has a decent range for opening the door, but once the bulb has turned on the control range is reduced, often to uselessness, by the RF output of the bulb interfering with the receiver a few inches away.
The recommendation was always just to try a different bulb type.
Well, today at Big Orange, while looking for a replacement gate remote (they were out of stock!) I noticed that Genie (the garage door opener maker) is offering under their brand an A19 LED bulb which does not cause interference. Reasonably priced at only $10.
Find a need and fill it.....
