ptonsparky
Tom
- EC - retired
A few years ago I personally had a fan that when switched Off would trip the GFCI for the Freezer. Totally different circuits. I used a device from RK electronics to filter out the problem at the fan motor. IDR if I changed the switch at the time. I tried different brands of GFCIs with no success.
Today, we worked on a similar problem that was causing the TV satellite box to reset just about any time they switched Off the fan. Yup, just as they said but occasionally it would trip the bath GFCI. Different circuits. I have nice meters and voltage drop or interruption was not the problem. We replaced the switch to the fan with a commercial grade, what we had, and problem solved.
Are the fans the problem or is it that the switches are getting to be so poorly made?
