Not that I know of.Is there a product available that you can screw onto a RG 6 connector to convert to a female phone jack?
Thanks
They make such an adapter from BNC to RJ45 but I don't know about to a telephone jack.
Passive or a powered format converter for wired Ethernet?
I have seen both now that you mention ethernet converter. Haven't seen one of those in a long time. I can't say I've ever actually used BNC to RJ45 adaptor but I've seen them in catalogs. I have no idea what you would use it for.
Among other things a phone jack (RJ-11) can have up to four conductors while a coax has at most two.
Yup.Just to pick nits, by definition an RJ-11 has only two wires (tip/ring of a POTS line). The same 6p4c connector might also be an RJ-14 (two POTS lines) or an RJ-12 (one POTS line + key system control leads).
That said, there are BNC -> screw terminal adapters.
Thanks
