RGS to PVC conduit transition
Designer69
Need to have an RGS conduit above ground to a wall mounted box and transition to PVC as it goes underground. Anything special needed to consider with this? I am thinking a simple coupling fitting will do.
Thanks
jeremy.zinkofsky
nj
Thanks
Are you entering the box with rigid and leaving with PVC? Or are you leaving the box with Rigid and changing over to PVC right before it enters the ground?
If it is the latter, then a rigid coupler to a PVC male connector will be your best bet.
Designer69
yes it is the latter. Thank you
quantum
LA
What they said, use a PVC female adapter. I would also use RGS for the elbows under ground before making the transition to PVC.
