mshields
- Boston, MA
I have always specified RGS for outside and exposed applications. Is Rigid Aluminum equal, not as good, better or a little of both?
Thanks,
Mike
Thanks,
Mike
Not as durable as GRS. But ok if not subject to physical damage.I have always specified RGS for outside and exposed applications. Is Rigid Aluminum equal, not as good, better or a little of both?
Thanks,
Mike
I would never put aluminum underground.In soil or above ground?
coastal - e.g near slat water.
Case history - Honolulu airport, many decades ago, new construction used Al rigid underground. Within 3 years ome already deteriorated due to iron/sulpher, etc. content of volcanic soil. Only galvanized now, or stainless in some applications.
What is the chemistry of your areas?
I labor it higher than I do rigid. It often does not thread well, and you really can't adjust a bend like you can with rigid because it work hardens, and instead of adjusting the original bend, you end up with a bend in a new spot on the pipe.Aluminum won't rust away and is much easier to install which IMO makes it better.![]()
The bottom line is that I had to cut the LB hub in three places to get it off of the conduit. And, I really tried.
I tried to unscrew it after each cut. It still took hard hitting with a hammer after the third cut, which divided the body in two, to separate the pieces from the conduit. The threads were filled with oxidation.The buried run I was talking about unscrewed from a coupling like I did it yesterday. I remember using Penetrox on the threads.
I did a "try" fit up, only hand tight into an LB, and ended up crushing the pipe to get it out, and it had a lubricant on the threads.Some years ago, I had to remove a 4" aluminum LB from aluminum conduit to re-route an outdoor feeder.
Use it a lot in sewage treatment. Hydrogen sulfide wreaks havoc on most other metals.aluminum is better in most applications, imo. terrible for chlorine. great for chocolate syrup.
have to look where it is being installed.
