mknoblock
- Livingston,TN Overton
My work experience has only been with residential inside wiring for railroad office buildings. I am running new electric service into a mobile home and have to pull 4/0-4/0-4/0-2/0 aluminum service cable through 2" PVC.
What's the smart way to do this? Assemble the entire conduit run first, then pull with lube? A typical application is 3 sweeps over about 25 feet with an LB at the end before rising into the service panel. I assume it's not a good idea to slip all the fittings over the cable and cement them with the cable inside... More than 2 sweeps makes this a tough pull .
thanks for any help...
