jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
I don't run much rigid at this time, I have run a lot with some bosses. I'm sure everyone else has seen this problem to a degree. Put a 90 or offset into the run, tighten wrench tight as code requires. Bend is not as needed. Loosen 1/4 turn, no longer wrench tight. Kill yourself getting another turn in the conduit, only other way to line up the bend. Code doesn't specifically forbid this, but would it be wrong to wrap threads with Teflon tape? That widens the margin of wrench tight. I've never tried it, never seen it done. But it would be a much easier way to line up the bends as needed, without straining muscles. I've put a meter on water & air lines with taped couplings, they ohm out just fine.
Thoughts?
Thoughts?
