Obviously not. I would add a thread sealant.Water is migrating thru threads
Is this connection rainproof?
See section 300.6 A for thread compound commonly called Penetrox E, its a copper compound that is great for threads and lugs.
Messy as "it gets home before you do" but I carry a bottle in my tool bag
No on thread compound. Never had an issue with water leakage in rainy Seattle area. Any plumbing thread compound would not be listed for electrical threadsDo you use thread sealant for rigid threaded conduit?
Don’t that prevent conduit Continuity same like on water heater so we need to use bonding wire
Looking at your image 2 of the pipes are not set as deep as the others, pitch unlikely issue, more likely ran too many threads causing "bottoming" before tapering seals into Hub. But most likely (if factory treaded) is installer never tightened pipes into hubs.Thank you all for your Help... called manufacture, no pipe dope needed. the seal is made by tapper threads.... I‘m thinking threads have wrong pitch and pipe in bottoming out before taper in closing seal.
Why would you prefer duct seal over silicone sealant?...only option might be duct seal on the tops of hubs at pipe penetration.
I know duct seal is listed for use on electrical installation, just not sure of any silicone based products, maybe someone else can comment on a listed silicone product.Why would you prefer duct seal over silicone sealant?
If you wanted to paint a conduit, would the paint need to be listed on electrical installations? IDK, but I think no and that's what I think about silicone on the outside of a fitting to block out water.I know duct seal is listed for use on electrical installation, just not sure of any silicone based products, maybe someone else can comment on a listed silicone product.
I'm not sure I understand this, it sounds like you are saying this in response to using silicone outside the threaded joint. I doubt there will be a problem with this.One additional consideration on loose pipe connections, is if pipe is used as an effective ground path, the "tight" connection is part of making that secure, and may affect the effective clearing of a fault condition.
I think this needs serious consideration.Might be coming through somewhere else in conduit upstream?
Thanks, didn't think of that factor, and some silicone is paintable.If you wanted to paint a conduit, would the paint need to be listed on electrical installations? IDK, but I think no and that's what I think about silicone on the outside of a fitting to block out water.....
IIRC, the plugs in a WP box are supposed to have a sealant applied (after installation) to get the WP rating. To me it's same/same
....I'm not sure I understand this, it sounds like you are saying this in response to using silicone outside the threaded joint. I doubt there will be a problem with this.......
This comment was separately just referencing "if" pipes are loosely fitting the additional issues could present, and additionally seperate from issue of the "sealing" of pipe for water penetration.One additional consideration on loose pipe connections, is if pipe is used as an effective ground path, the "tight" connection is part of making that secure, and may affect the effective clearing of a fault condition.
