We have five story building, and each floor has a dedicated electrical and telecom room, each with ground bars. Is there any issue to use one vertical riser bonding conductor (say 250 to 750MCM) to bond all the electrical and telecom ground bar on each floor? Note: The riser bonding conductor will be bonded to the main electrical ground bus. Or should there be two separate vertical rise bonding conductor for each grounding system?
