M mstrlucky74 Senior Member Location NJ Dec 26, 2013 #1 What is the most commmon way to support armored fiber cable running vertical in a riser?
Ponchik Senior Member Location CA Occupation Electronologist Dec 26, 2013 #2 If you are using a conduit system I would guess one of these will work. http://www.emersonindustrial.com/en...ng/cable_supports/OZGEDNEY_Cable_Supports.pdf If you don't have conduit system you can probably install a short piece of conduit on every floor penetration and use the mentioned support. I am sure others will have better solutions for you.
Rampage_Rick Senior Member Location British Columbia, Canada Dec 27, 2013 #3 I've seen a 20-storey building with fiber to the cell towers on the roof. One provider ran their fiber inside 2" FMC with the top end anchored by a Kellems grip. The second provider zip-tied their fiber to the FMC.
