Mikie B
- Detroit MI
Has anyone out there replaced a riser panel in a high rise apartment building? Panel is fed from unit below and feeders passe thru inside of an attached gutter to feed units above. I've seen retro kits where you just change out the "guts". This will not work in my situation because the cover/door is broken and is the cause for replacement. My latest thoughts are to install a separate gutter to enclose the feeders, then install a regular panel. I would love to not cut & splice the feeders, hence the reason for the gutter, but I realize that may not be possible. Any helpful info will be GREATLY appreciated! :blink:
