mstrlucky74
- NJ
Existing Riser and panel. Adding new disconnect switch which will be powered from existing riser(they want a tap). I think these insulating piercing taps will do the trick. Any reason you see these would not be able to be used spec not withstanding? I know I can't exceed 10' for tap. Thanks.
https://commerce.ilsco.com/e2wShopp...d=3100012541&parentLink=2100001183:3100012541
