I have a project where I have a 260 ft River crossing using an 1/2" galvanized aircraft messenger cable with minimum breaking strength of 24,000 LBS.
The messenger will carry 8 conductors. Each conductor will be #8 AWG Stranded CU with RRH insulation. Three Aircraft Hazard Balls will be attached to the cable.
I have asked several Cable manuglfacurers to fabricate this composite Cable and deliver 300-ft of it on a single cable reel.
However, they have responded with up to 18 weeks delivery time. Which is loner than I want to wait.
If I order the cables and messenger seperately and wrap the cables around the messenger wire myself, I can get the wire much sooner.
The problem is I am not sure if I can do a proper job of wrapping eight #8 stranded conductors around the single messenger wire by hand.
I thought, perhaps, to stretch the messenger cable between two vehicles and then, one by one, wrap each 300-foot run by hand individually. I am just not sure if I can get all eight conductors to lay down correctly onto the messenger cable surface in an even spacing.
Also I would need to know the correct number of feet per turn I should use.
Does anyone have experience wrapping this many conductors onto a single messenger? Is thwre a wire spooler out there I can purchase that can do the job?
