Bill Turax
- MD
I was planning on using an old Westinghouse 400 amp MCB panel to add 6 new circuits. the panel has plenty of capacity and more than 6 spare slots.
When we removed the dead front to install the breakers we found that the threaded bolt holes for the breakers were filled in with what look like pop-rivets?? see picture attached.
before I recommend the customer replace the panel (it is old anyway) I just want to check to see if any of you have seen this before and have any idea why this was done. My only guess is that the threaded holes were stripped out and they installed theses rivets to tap into them due to the soft metal? I definitely don't want to do that...
