RMC over roadway
225.60 is for systems over 600 volts and 225.18 is for systems 600 volts and less. Neither apply to conductors in a raceway or cable tray.
I'm not sure how I missed the "over 600 volts" for 225.60 - thank you. I will use the 18ft height referenced in 225.18(4). I am curious since 225.18 specifies "open conductors" what an AHJ would say about clearance for a pipe bridge over a road on an industrial site used for personnel carriers and small trucks only.
Many industrial pipe bridges are less than 18' their roads. I believe the maximum height of a vechicle on a public roadway is 13'6" unless they have an "over size load" permit.
Here are some of the details on the machine.
Specifications:
~ The mover stands 311 feet tall and 705 feet long.
~ It weighs over 45,500 tons
~ Cost $100 million to build
~ Took 5 years to design and manufacture
~ 5 years to assemble.
~ Requires 5 people to operate it.
~ The Bucket Wheel is over 70 feet in diameter with 20 buckets,
each of which can hold over 530 cubic feet of material.
~ A 6-foot man can stand up inside one of the buckets.
~ It moves on 12 crawlers
(each is 12 feet wide, 8' high and 46 feet long).
~ There are 8 crawlers in front and 4 in back.
~ It has a maximum speed of 1 mile in 3 hours (1/3 mile/hour).
~ It can remove over 76,455 cubic meters each day.
~It requires an external 16.6 Megawatt power supply to run
This link has some better pictures of the CAT being removed from the bucket.
