JJspark
- Denver, Co., U.S.A
Can you use a RMC threaded coupling to transition to LFMC?
Debatable: Code vs. Listing (design, instructions).
It's been practiced by many without consequence, and will continue to be practiced by many. However, there are AHJ's and others that say a LFMC connector is designed for raceway termination at/through an enclosure KO and not for theading into an RMC coupling.
How would that be different than using an EMT connector threaded into an RMC conduit body?
Well gee, wouldn't you think that after 50 or so years of folks using these products this way that somebody would say "lets investigate and get 'em listed" for this use?
Not compliant either. EMT fittings are covered under FKAV and are only investigated for use with lock nuts. Same as KDER and DWTT for other related products. I know, this is just crazy. Any time I mention this to our UL rep I get the standard answer of "these were not investigated for this use". Well gee, wouldn't you think that after 50 or so years of folks using these products this way that somebody would say "lets investigate and get 'em listed" for this use?
Then they would have to rewrite the standard, and possibly delist a whole bunch of stuff that dies not meet the new standard.
Why?
Then they would have to rewrite the standard, and possibly delist a whole bunch of stuff that does not meet the new standard.
As a practical matter nothing will change until and unless inspectors start failing installations that violate the listings.
fmtjfw;1578006 Or do you think that all the current fittings can work unaltered? .[/QUOTE said:Yes.
They already have been functioning fine for years.
Do they say how the lock nut is to be used? Is it OK to use it like a jam nut between connector and fitting? IOW, outside the enclosure vs. inside.
This has been discussed in IAEI meetings before.
You guys go first and we'll see how that works for you. :huh:
