fracas666
- Northern New Jersey
Article 352.100
Rigid Nonmetallic Conduit (RNC) construction specifications states that RNC and fittings shall be composed of suitable nonmetallic material that is resistant to moisture and chemical atmospheres.
Article 100 Definitions
Fitting. An accessory such as a locknut, bushing, or other part of a wiring system that is intended primarily to perform a mechnical rather than an electrical function.
Does this mean that metallic locknuts cannot be used with RNC male adaptors? If so, are PVC locknuts produced over one inch? If not then I guess that all of these years I should have been using PVC box connectors for connecting to electrical enclosures. Also would a strap be considered a fitting, as it is part of a wiring system that is intended primarily to perform a mechanical function? This would answer the question of using metallic straps on PVC.
Ron
Ron
