RNC Expansion Fittings
iwirehouses
Rather then calculating the equation in the NEC to figure out how much the earth will move, I'd just assume put an expansion fitting in every vertical run going under ground. My question is, how come I don't see them anywhere? For example, you would need an expansion fitting to go from an LB to a 90 underground, a 3 foot underground run, then a 90 back up right?
