Sparkyyy
- Comstock Park, MI
- Master Electrician / Electrical Contractor
We have a brush painting robotic cell and need to know if it is Class 1 div 2 Explosion Proof or not?
There is a proposed Robotic Paint Cell with Four Robots in one enclosed Cell. Each robot is fed from a container with an enclosed pressurized canister located outside the room. There is approximately 16oz of Primer or paint that is OSHA Class 2 flammable Rated. A hose comes from the canister to the end of arm to a 2” wide brush. Each Robot coats a panel located on its nest that it will cover with a Primer, or Paint.
There are two Explosion Proof vent fans on the top of the cell roof that together exchange the air in the paint cell 1 or 2x per minute.
Each Nest has switches from cylinders and air cylinder movement via pneumatic valves. There are 4 light fixtures, Area safety laser scanners and Man Machine vision with several lights scheduled for this area.
Question:
Thanks for your help,
Question:
- Is this a class 1 dive 2 environment as far as the electrical wiring is concerned or not. Due to low volume in the area and no atomization I am hoping it is not.
