Rolling offset
Sparky1205
Panama City Fl
Journeyman Wireman
I’m reaching out to see if there is a way to match the second center of bend on a rolling offset when the roll is different for each pipe but the rise stays the same, I can match the first center on all three pipes but Im not sure of a way to match the second centers never really heard of it. Thanks!!
Any of these like your job? Honestly, I'm more of a bend-it-by-eye with a folding ruler kind of guy.
Yeah I got something similar going on but I think I figured it out, someone correct me if I’m wrong. But you adjust the degrees to get the same space between bends. Ex. If it’s 27” between bends on a 30 degree, you would change it to 32.5 or similar when you bend the next pipe in order to get your same distance since the roll will be different on each pipe.
Ugly's electrical referenced has a section on conduit bending that is really helpful.
