Romex Cable Connector?
ScottMRVA
New User
Richmond, VA
Hi All! I am wondering if there is a cable connector that can be placed on a cable that is already terminated and going through a box or enclosure? If so, links?
Thanks!
Scott
You can use any one of these two, slide it over the cable and push it into the KO. You will need to slit the one on the left.
View attachment 17559View attachment 17560
I use the one to the left a lot.
They are great for retro wiring. You can slide it on the cable after you pull it throughthe KO and they take up less room in the j box or oanel.
Peter d... If you "nibble away at it"to make it work for you doesn't that ruin the UL rating causing a code violation?
