Riograndeelectric
- Lakewood Colorado
On a basement finsh I will be starting on the framers are installing the 2x4 studs on the flate side like furring strips.
in order to support the Romex cable horizontally and not have to drill out the studs I am having the framers use 2 studs for each vertical member and leave a space at 48" off the floor about 2" wide. to run horizontal
since the 2x4 are layed flat you can not get the 1 1/2 inches of set back from the front of the drywall and is this code compliant ?
the reason for laying the 2x4 flat the room is very narrow only 10 foot wide so the HO does not want to loose valuble wall space by having the full 2x4
