What is the attic temp in the summer? 86f deg 100f deg or 140f deg.
Now NM cable is rated at 60c right. Now read article 334.80 I find this funny. If you get it then post your thoughts.
Now look at the correction Factor, if the wires are tested at 86 F per 310.16 and if your attic does not reach over 131F you will be ok with NM cable. Correct right
Now what the real temp in a florida attic.
oh don't forget to derate
