CopperTone
- MetroWest, MA
I don't believe I can do this, but I seem to remember discussion about this. I want to feed a shed sub panel from a residence with 8/3 romex or NM in the basement, then strip off the sheathing after it enters the LB and down into the conduit underground 30 feet to the shed new sub panel. Detached structure - will drive a ground rod at shed. Can I use this type of wire in this setting if I strip off the outer sheathing where it is in the conduit? it would make my life much easier but I want to do it right in the end.
