romex in garage
JDB3
In the wiring of a residential garage with a work area, that the walls will not be covered with anything, to what height would the romex need to be kept without physical protection? {{ The ceiling & walls both will be open.}}
Thanks. :?
Thanks. :?
AS long as it is a dry location you can use it.
You only need to protect it if you think it will be subject to physical damage....:thumbsup:
Read 334.12...
Read 334.12...
I will go one step further and say if the nm is run along the framing members or boards then it is compliant. I think it can be argued that a free span between studs is not protected from damage.
Yes I can see that turning into a handy tool hanger.:lol:
There is, to my knowledge, no specific height. Folks in this area have normally figured anything below 8 ft as sublet to damage loosely basing it on 300.5(D)(1
it is a common misunderstanding among home inspectors that "Romex within 7' of the garage floor must be protected"
