CopperTone
- MetroWest, MA
I think I can do this legally but here is the situation. I need to run a circuit to the kitchen from the panel which is recessed in the wall in the living room about 30 ft. No access from above or below so they are requesting wiremold 500 surface mounted up high on the wall with 12/2 romex (NM cable) sleeeved through it.
is that legal to do or do i have to strip the outer sheathing? , is a bare ground wire legal if I take off the outer jacket in the metal wiremold 500 conduit? I will be using a wiremold single gang box at each end of the wiremold run so I would need to use a ground screw and ground the metal box so I would strip the insulation in the box anyway.
