I have 2 questions:
1. Running 10-3 UF outside NOT in the ground but tacking is under my deck to hook to a pool pump. Can I drill a 1" hole in the floor joists of the deck and run the cable throught it or do I have to staple it?
2. If I can run the 10-3 through a drilled hole, can I put 12-2 UF in the same hole or does it need a seperate hole or a seperate staple?
Hope I did not confuse you!
THanks,
THanks,
