keith gigabyte
- New Kensington, Pa
Bidding a multi family dwelling. It is a 3 story large home with basement partially below grade. It is being converted into 4 units..one on each floor level. It is a brick home build around 1910. with the exception of a few existing 2x12 floor joists the interior is new construction 2x4's and engineered wood beams. The exterior walls are original brick load bearing. Now that you have an idea of construction type, I feel it falls under type III construction in annex E.
I read and re-read 334 uses permitted and uses NOT permitted. As I read it I can use nm cable throughout correct?
Just always heard romex I is not allowed f building over 3 floors; and do we count basement since its finished? Which would make this building 4 floors.
I am going to check with the inspector but I don't like to ask a simple question like this and seem inexperienced.
Thanks.
Thanks.
