My temp. limitation is about 15 degrees depending on the wind chill. Seriously the NEC is silent on this issue.I am wondering if there is a temperature limitation to instally nm cable? the temperature outside is 5 degrees. Thanks you
Some manufactures of PCV type cables and conductors have statements that you are not to install the product if the temperature is less than 14?F.
What type of NM cable? If its NMB "romex" like you use indoors it is not listed to be used outside even if it is in conduit.
