Don't have a lot of experience with rommex, but recently it seems that's all I'm doing.
Anyway, I'm doing a house right now and I have 2-3 drops that I have to bring on the outside.
If I understand the code correctly, we can not, any longer just bring the rommex out and sleeve it through a conduit (cause apparently rommex is not outdoor rated, and even inside a conduit it would still be considered "outdoor" SIC)
So My question is this: The wires in the rommex are THHN? right? And THHN is outdoor use, so apparently is the sheath that is not? So if I strip the rommex to the point where it enters the conduit (still inside), put a connector on the conduit, a threaded coupling and a rommex connector, then install the wires WITHOUT the sheath into the conduit? Would that be code?
