Ask for a code reference on why you need the disco
Sent from my SAMSUNG-SM-N920A using Tapatalk
Fresno has a municipal code that requires a DC disconnect, not AC. A few of the surrounding AHJs have adopted a similar stance. Moving forward, you should be able to sit down with the fire official and explain that the new requirements for rapid shutdown (micro-inverters are compliant) preclude the need for a handled box on the roof.
FYI - the relevant language is buried in Chapter 10:
605.11.3. DC Roof Top Disconnects. There shall be a separate emergency DC disconnect on the roof to disconnect solar panels from DC wiring running through, and on, the building to the inverter. This disconnect must be permanently labeled in reflective, fade-resistant material that states: "Emergency DC Disconnect." Disconnects, shall be in a NEMA 3R box, and shall be installed as close to the array as possible to reduce the length of energized wiring that cannot be shut down. Commercial installation where multiple disconnects are required will be evaluated for approval on a case by case basis by the fire code official or designee.
