Roof penetrations
Alwayslearningelec
NJ
Estimator
When you guys have to penetrate existing roof for your conduits do exclude the penetration and state by others or just the sealing etc ? Thanks
Are you referring to a roof in a commercial building? I don't think that any electrical contractor would want to take on the liability of a leak unless they were going to sub out the sealing job.
Actually industrial job. You would exclude penetrations?
Will you be subbing it out to a roofing contractor or will the foreman send the apprentice up to the roof with a bucket of tar? Unless one of your electricians is also a professional roofer IMO it's not worth the potential liability associated with a leak to get involved with patching any type of rood penetrations.
Yes but I'm referring to the actual coring/penetrations of roof.
"All roof penetration sealing and flashing to be performed buy others"
Just another line item in the contract, along with all the other things we don't/won't do, like repairing pretty much any finished surface, compaction and grading, etc.
We cut the hole and run our pipe, then the roofer handles it from there. I also coordinate with the roofer and/or GC so we aren't leaving a hole open for weeks. We do seal penetrations on vertical surfaces and I'll stick a boot on a mast before I install the weather head, but that's about it. You don't want the liability of dealing with roof penetrations, water can cause massive and expensive damage.
Except maybe spell by correctly..
