Eros
- United States
Where can I find the "setback" rules/guidelines for installing solar on a roof and who enforces this. I seem to be getting conflicting info from different municipalities
thx
thx
thx
And you will. Some AHJ's enforce fire code and some do not.
And some have local amendments or interpretations and some do not.
Without knowing the state where the installations are being done it's very hard to start to answer the question.
michigan
thx
If you are in Michigan, there should be no differences in codes from one municipality to another. Michigan adopted statewide consistency a couple code cycles ago.
The building and electrical code requirements can be found on the Internet if you are 'net savvy, or you can call the state directly.
For construction codes: 517-241-9313
This page has a list of other state phone numbers you may like to have:
http://www.michigan.gov/lara/0,4601,7-154-76106-42245--,00.html
I have called the state several times with questions and found that they are very helpful. If the number I listed isn't the one you need, someone will get you to the person that can tell you the answer to your set back questions, and they will be reading the answer from the state regulations.
As I mentioned, the entire state has to follow the same rules with one small exception. Agriculturally zoned land doesn't have to follow codes. Other than that, the rules are the same from municipality to municipality.
Lucky you. In Texas we have to contact every municipality and ask if they enforce fire code. Some do, some don't, and it makes a difference if the building in question is in the city limits or not or in the extended jurisdiction of the city, so we have to check the specific address.
