electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I have a roof mount PV system where it is not possible to get to the panel inside the structure. The feeder come from a pedestal UG and thru the slab into the middle of the house. The meter pedestal is a 200A meter main with spaces after the main and feed thru lugs which is what is serving the house. I am confused about which ways are acceptable to interconnect the PV system to the pedestal. My first though is to run a 100A feeder over and set a panel in the carport (attached to the house) which would also be handy for other stuff. However this gets into two feeders serving the building, 225.30. There doesnt seem to be an exception for a PV system, or does "parallel power production system" cover it? I dont see a definition of "parallel power production system".
What about setting up such that it is in inverter output circuit and not a feeder, would that make a difference?
Code is 2017, and inverter would likely be a string inverter.
