Hello,
I am curious on how a privately-owned rooftop antenna should be grounded. I know 810.21 requires that the antenna to be connected to the grounding electrode system in a few ways:
Thank you
- via the intersystem bonding termination
- or directly to the grounding electrode system. Whether it's a water pipe (Within 5'), building structure, or the grounding electrode conductor.
- Bond to exposed rebar if that rebar is continuous to the rebar at the ground level that is considered a grounding electrode conductor?
- Bond to a telecom bonding busbar inside a telecom room closer to roof level? Is the telecom bonding system considered an intersystem bonding termination if it eventually connects back to the grounding electrode system?
- Or does a dedicated conductor need to be run all the way down to the grounding electrode conductor or water pipe entrance?
Thank you
