codeunderstanding
Im going to wire a 1965 Hardinge metal lathe machine in a residential garage.The lathe is a 1.5 Hp 480v machine. I was going to install a 5kva step up 240-480v transformer. From the transformer run into a combination disconnect 480 volt across the line starter. From the starter go in the 4 kva rotary converter and then into the disconnect for the lathe. Does anybody see anything wrong with this installation?
